my brake master cylinder is going bad and i have never changed one before so i wanted to get a little info.
Changing brake master cylinder
you need to start by trying to remove the most brake fluid for the reservoir. use a needle or rags to suck most of the fluid out so you dont make a mess.
use a quality 10 mm line wrench to loosen both brake lines, just break the loose do not remove them just yet.
use a extension, ratchet and a 12mm socket to loosen the brake master cylinder. remove both nuts. and unplug the sensor in the cap of just put the cap to the side.
now remove both lines and pull the master cylinder out.
bench bleed your new master cylinder. install it just reverse order of up top. tighten both lines and bolts.
now its time to bleed the brakes.have someone help you
start with the furthest from the master cylinder. and work your way in to the closest. top off fluid as necessasary and keep doing till you get a firm pedal.
hope that helps, if anything that you don't understand anything from above the google it or better yet, buy a helms or haynes manual from you local auto parts
Yes a lot of emphasis on this. please don't use the shitty autozones ones.Originally posted by JaK FRoSTWhiTE View PostMost important right there...
Get a LINE WRENCH!
If you round out the brake line you're screwed!
Craftsman work very well for the prize
