Break pedal
    Break pedal
    Well i got my front pads changed and now the pedal goes all the way to the floor for it to stop. Now i searched and found out that it could be the master cylinder. I dont think i have a leak so if i bleed them will it help my pedal. (also the pedal only goes all the way to the floor when th car is turned on, and when the car is off it feels like it did before the pads were changed)
    hm.. brake booster maybe? try bleeding the brakes where u changed the pads.
    alone in this game . ::My Ride My Way::
      brake need to be bleed
        Bleed the brakes.
        How's your fluid level?
        Are you running rear drums?
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          Fluid level is good and yes have drums in the back. Will bleed brakes tomorrow see if that changes the pedal.
            my car is doing the same thing except i havent changed my brake pads..so keep updated on how that goes tomorrow
              i have the same problem too
              i didnt bleed the brakes yet..
              but tell me how that goes too
              i might do that this weekend
                Could be bad calipers maybe.
                1991 Honda Accord EX F22A1
                Coming Soon... F22B DOHC w H23 Tranny
                "My phone kicks in a 5000 RPM's"
                  Well got done bleeding them and it did fix the problem now the pedal is how it used to be and the car stops with no problem. Hope that fixes your brake problems bleeding them i mean.
                    if there is anything wrong with the booster or something is seized such as a caliper or a wheel cylinder it will give you a harder pedal. the only (common) thing that will cause a soft pedal is air in the lines or a bad seal in the master cylinder.
                    hope you luck
                    edit: aah crap... you beat me to it. glad to hear you fixed the prob
                    My Rides:
                      well im glad its somethin simple
                        Fyi...
                        BEST BRAKE PISTON RETURN TOOL EVER !
                        http://www.weblumen.com/subaru/image...ssion-tool.jpg
                        lol
                        A must have.
                        Oh... and crossed drilled rotors ....lol, NOT slotted.
                        Oh... and powder coated calipers...lol
                          lol
                          A must have.
                          That is a nice little tool. But I just use vise grips to push the piston back in. Matco wants 40 American dollars for that tool. Way too expensive when vise grips work just as well.
                          "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
