My cb7 accelerates by itself. Like when its in park, the RPM goes up and down. What can it be? any ideas
Accelerates by itself
well not if it idles up and down..Originally posted by CO-jack View Post
you gotta clean your iacv valve probally..
Ride: 2002 Lexus IS300
same thing happened to me when i installed my h22- it would just free rev- i had a leak in the im gasket
Bought from: 92acclude, almostJDM, cali-racer, MikeW, rexload, slick, sackingz123, so-calsfinest, lindiz, yeamans17
Sold to: timmy0tool, sackingz123, judonoh, jdmhondaman, jdmaccord91,Ofr
mycb7.com
Members Ride
yeah u gotta love that loping idle hdas seem 2 develope mine does also but i know that i hve a crack in 1 of my runners on my i/m. just a matter of finding another a6 or h23 i/m. cool but i have slowed it down and most of tim its not noticeable this is what i did \.started car let warm up 2 fan cycles loosen distributer and turn all the way retarded my idle prob stopped but now i was timed 100% retarded lol.
so knowin tat its permitable 2 run 2 degrees advaced or retarded with no probs so i timed it 1 degree retarded i still get a bouncy idle sometimes but not nearly as often and when i do its not very much. cant say this will help every 1ns idle prob since the prob could b caused by so many spots on the i/m. inspect ur vaccume lines carefully inspect ur intire i/m for crak or damage the bet way 2 determin a leak is with a can of throttle body cleaner. spray all around ur i/m whil car is running if u hit the spot the car will drop in idl and sound like it wants 2 stall that will tell u where the leak is. good luck and happy hunting
