rpms
    rpms
    i have a 93 accord lx and my rpm gauge goes all crazy when i drive and sometimes it putters and then my car will die and then it wont start for like 5 minutes... but it only does it sometimes.. can anyone help me out tell me what it might be
    93 accord lx
    Sounds like the Igniter chip is going out. You can replace it from one from autozone it you have to know how. It isn't that hard just search in the search box at the top of the page. Or you can replace the dizzy.
    -1991 Honda Accord LX H22a-
      Yeah, the igniter is the most likely culprit. Easy fix. If you have any u-pull-it yards near you, go in and grab a few. Grab some coils while you're at it, as they fail as well.
      Also, another possibility is your grounds. Check all ground points. Make sure they're clean and tight. Pull on the wires, since sometimes they may look like they're attached, but they've really snapped (my fender ground did this... I couldn't figure it out, because it looked attached! I bumped the wire and it came loose... found out by accident!)
        sweeet! ill go and try that 2 morro.. thanks for the help
        93 accord lx
