Starter Problems
    Starter Problems
    earlier today I went to mcdonalds and I was going to leave but car wouldn't start.I figured it was the starter so I pushed started it to get me home.so,I went the auto parts store and got a new starter, went to test start it and nothing.so I jumped the starter off to the battery and the car started.all in all, i'm here to diagnose the problem and hopefully you guys can help me.any feed back is greatly appreciated.thanks.
    I don't suppose you hauled the battery to the parts house with you to have it load tested did you?
      you jump and work? alternator?
        have had a lot of alternator/battery problems lately as well, try this:
        1. have the battery load tested, while you are there make them charge it for you.
        2. do the battery cable test on the altenator, get the car running somehow and pull the pos+ cable off. If the car shuts off, it is deff the alty.
        3. if it turns out to be the alternator remember to have a new, or fully charged battery or you could overload the altenator and render it defective. Also. tigthen
        the tesioning screws back to oem specs, most ppl try to leave it b/c it is hard to
        reach at times.
        godspeed
          reach at times.
          godspeed
          x2
            re:
            first i havent had the alt. checked out but,for the battery part,its an optima blue top never had any problems ever since i got it 2.5 yrs. ago.i was thinking more along the line,of neutral safety switch,but just wanted to get more suggestions. thanks
