So, gotta f22a6. Automatic. I've been searchin' for about an hour now, tryna figure out if an Ecu from a prelude (h23), would put an advantage on my a6 Ecu I have now. I read up on the f22's in the preludes and accords (a1's), with the prelude havin' an extra 10 horses on the a1 in the accord, 'cause of the Ecu. Is that similiar from the h23 to the A6? Since they both have the IAB sytem and all. (In about 2 weeks, I'll be throwin' a h23 plenum on).
h23 ecu...f22a6
as a rule of thumb with ecu's, a stock sohc ecu will run a dohc engine and sohc. a dohc stock ecu will run only dohc engine, (ok it might run but not driveable or worthwhile).some cars have wings cuz they look cool.
some cars have wings cuz they increase efficiency.
some cars have wings to keep them from taking flight.
f1 fan
The P12 is not a significant upgrade for the A6. The ONLY ECU that might be good, and I'm trying desperately to find someone that can give more info on it, is a European ECU for the F22A7. Unless the specs I saw were a typo, this motor makes 150hp, and seems to be similar to the A6. If so, it might be a situation like the P12 for the F22A6. I can't get anyone to find any info, though! The specs I saw online might have been false.
I don't know for sure if the P14 (H23) ECU will do anything good for you, but probably not.
i have seen the specs you speak of and have seen the same corresponding specs on at least 3 different sites but can not verify the factsOriginally posted by deevergote View Post, European ECU for the F22A7. Unless the specs I saw were a typo, this motor makes 150hp, and seems to be similar to the A6. If so, it might be a situation like the P12 for the F22A6. I can't get anyone to find any info, though! The specs I saw online might have been false.
that ecu in theory should be some sort of upgrade
from wikapieda
F22A
This engine series was used in the Honda Accord and Honda Prelude S. Aside from differences in tuning, these engines are substantially similar.
Specifications
* Bore × Stroke: 85.0 × 95.0 mm
* Displacement: 2156 cc
* Valve Configuration: SOHC, 16 valves, Non vtec
* Compression ratio: 8.8:1
* Max power:
o F22A1: 125 hp (93 kW) @ 5200 rpm
o F22A4: 130 hp (97 kW) @ 5200 rpm
o F22A6: 140 hp (104 kW) @ 5600 rpm
o F22A7: 150 hp (110 kW) @ 5900 rpm (147hp/108kW with automatic transmission)
* Max torque:
o F22A1: 137 ft·lbf (186 N m) @ 4000 rpm
o F22A4: 142 ft·lbf (193 N m) @ 4000 rpm
o F22A6: 142 ft·lbf (193 N m) @ 4500 rpm
o F22A7: 145 ft·lbf (198 N m) @ 5000 rpmLast edited by sleepycb7; 06-23-2008, 11:09 PM.some cars have wings cuz they look cool.
f1 fan
Well, see....the engine I have now, is an A1. BUT...I've exchanged the intake manifold from the A6, have an aftermarket header, and my IAB system works properly. Now, I took my plenum off already, and took the butterflies out.
So, not having the IAB system, I guess doesn't matter anymore. Once I get the plenum, I'll be purchasin' a spacer also, and on the DIY for the h23 plenum swap, the guy takes the butterflies completely out, and welds the holes. I still have the system and everything, just don't have the actual "wings" anymore. It helps, cause now they're open at all times. Very mean growl now. What exactly does the ecu in the f22a1 in the prelude..give the benefit to? Where's the extra 10 horses come from, from that Ecu? The only thing I don't have from th A6, to make my engine a complete f22a6, is the Cam. But, I plan on sendin' it somewhere, to get it shaved to a 260, so that's in the works. The only reason I won't take the butterflies fully out, is cause there's plug(s) that hook to it, so...if I was to unplug the stuff, don't wanna get a random CEL.
98' Mustang 3V Swap
11' VW CC R36
I own a CB3 (?!) Honda Accord Aerodeck (wagon) 2.2i with F22A7, it does indeed give 150HP, and I'm looking for ways to get data from the ECU in order to display consumption, speed, revs etc. while driving. Can the specs of the ECU be found anywhere on the case? I don't know where the ECU is, and how to get into it.Originally posted by deevergote. View PostThe P12 is not a significant upgrade for the A6. The ONLY ECU that might be good, and I'm trying desperately to find someone that can give more info on it, is a European ECU for the F22A7. Unless the specs I saw were a typo, this motor makes 150hp [...]
Yes, I'm a newbie in the tuning scene, so if you can point me in the right direction, I can tell you what type of ECU there's in the car.
Do you know the interface type (OBDI or pre-ODBI) of the ecu? Thanks in advance for any info.
1991 Honda Accord Aerodeck 2.2i PGM-Fi
F22A, 110kW (150HP) VIN JHM CB3 5400C xxxxxx (JHM = Made in Japan)
From the Land of the Blossoming Autobahns
chipped ecu with data logging.Originally posted by LMB View PostI own a CB3 (?!) Honda Accord Aerodeck (wagon) 2.2i with F22A7, it does indeed give 150HP, and I'm looking for ways to get data from the ECU in order to display consumption, speed, revs etc. while driving. Can the specs of the ECU be found anywhere on the case? I don't know where the ECU is, and how to get into it.
obd1.
while driving you would probably need hondata s300 but why???
ecu is on passenger side under the carpet and a metal plate. cant miss it
smoke tires, not drugs.
Thanks a lot! I thought it was ODB0.Originally posted by slammed4thgen View Postchipped ecu with data logging.
obd1.
The reason I want to get the data is to improve economy. I drive a lot in the city, and it's starting to cost.
For reference: the ECU is probably PT3-A12 (though not sure).Last edited by LMB; 08-08-2008, 08:18 AM.1991 Honda Accord Aerodeck 2.2i PGM-Fi
