driver side headlight not working....
    i just replaced my driver side fender today and in the process had unplugged my driver side headlight while the battery was connected... i meant to unplug the corner light (did that after i disconnected the battery) so i could get to one last screw in the fender. but anyway now i put everything back 2gether, all the lights work even the high beam works, only thing that doesnt is the low beam on driver side... did my light just magically blow out cause i did that or do you think it was a fuse? if you think its a fuse can you tell me where i find this fuse in my car??
    First check the bulb then the fuses.
    wat?
      yeah I think it may be the 40 amp fuse in the fuse box for the driverside headlight relay. Either that or your bulb blew.
      member's ride thread
      91 Accord SE 176k
        sound like light bulb
        yo tsx, here i come
          i forgot to add in that on the dash the little car indicator that lights up if u have a lightbulb thats bad or door open does not give any indications that its bad... and i know that works cause i had a tail light go out not to long ago.... i dunno if this changes anything
            na thats only for the brake light bulbs. the front headlights/corner/blinkers aren't affected or arent' wired to that circuit
            91 Accord SE 176k
