Would I be able to use a set of coil-overs from a civic on my Accord? I really don't even know if they are from a civic I'm just assuming they are. I found four Honda struts in a car at the junk yard the other day and the coil overs look brand new. They where inside of a Nissan Altima that was sold as scrap metal and the car was filled with parts from various cars. I was thinking they may fit but the spring rate would probably different because of the weight difference between the models.
Coil-over question?
no...the parts on civics don't swap to accords. The cars are different in size...preludes and accords are similar...but not with civics. Too small
even if they would swap the spring rates are wrong and you wouldn't want to do it
...this has been asked before, someone found a civic in a junk yard with konis...but eh...don't work__
__
no probs...if you do find some shocks...I wouldn't recommend using used, unless you KNOW they aren't more than a year or two old...imo and if you REALLY need replacements bad...otherwise new is the only way to go, I can't honestly recommend using used coilovers and cheap ones at that...not a good idea...but it has been done.
and on the search...in the beginners section that's not too uncommon...get's crowded quick and a post that is only a month old get's pushed down REALLY quickly...makes it hard to find sometimes.__
__
