brake upgrade...
    brake upgrade...
    since i have the fortune of havin a cb coupe with rear disc brakes, does anyone have any suggestions as far as performance upgrades? they are do to be overhauled soon anyway, so i might as well do it big!
    thanks in advance!
    mike
    http://www.cb7tuner.com/vbb/showthread.php?t=345
    check out the link
    A cheap way to upgrade your breaks are to get upgraded break line, there is a guy who sells them on here, get some good pads, that will the cheap way, the better root would be get a accord wagon calipers and put them on your accord. There is more work involved but that will give you an idea.
    Look up a guy named Reason (he sells the break lines) and also look up Losiracer2 he did the prelude or legend swap, and now he kisses the windshield.
    Click Me
      i dont think you need to upgrade the brakes in terms of size. get a good set of discs and pads and you'll be set.
      i like the power slots and the HPS race pads.
        Wed3k has a point...but you can look into these threads as well if you'd like
        http://www.cb7tuner.com/vbb/showthread.php?t=17795
        one I made after reading that thread
        http://www.cb7tuner.com/vbb/showthread.php?t=109048
        ____
          I'd suggest an Acura Vigor brake upgrade. It uses 11.1 inch rotors vs. the stock 10.2 inch ones, bigger calipers and bigger pads. This is for the front brakes only, which is all you'd need.
          You would need:
          -Rotors
          -Calipers w/ brackets
          -Pads
          My setup cost me about 325 w/ SS brake lines all the way around. Bolts to your stock mounting locations and reuses all the OEM hardware.
            thanks guys, this helps alot!
            i am really beginning to like CB7tuner.com!!!!!!!!!!!!!!!!!!!!!
