i heard if ya mill the head a little bit you get some more compression.. is it true?? and dose it make a differance?
get it milled
It'll also shorten the lifespan of your head. If you blow a head gasket and warp the head slightly after a mill, you won't be able to mill it again. It'll be garbage.
If you want to raise compression, get high compression pistons and do it right. If you're going to have a machine shop work on the head, get a good P&P instead. You'll get much better gains.
Milling the head (or top of the block) will also decrease the distance between the crank axis and camshaft axis, and this will retard the valve timing. It's not a lot and may not present any real problem on a road engine (unless you shave a lot off), but in theory it would be ideal to then fit vernier timing gears and have the valve timing carefully set up...Regards from Oz,
John.
Yes, it raises compression, as stated before. Same concept... it's an internal combustion engine. Since you ask that question, you obviously don't understand the intricacies of the process... and you clearly don't seem to care that they've been explained to you.
Also, shrink your signature. Nobody wants to see an entire page of your car every time you post.
im not stupid man... just never worked on a honda beforeOriginally posted by deevergote. View PostYes, it raises compression, as stated before. Same concept... it's an internal combustion engine. Since you ask that question, you obviously don't understand the intricacies of the process... and you clearly don't seem to care that they've been explained to you.
Gotcha. Backing off. Very sorry, sir. I don't mean to act like I run the place or anything.
And I never said you were stupid. Just that you didn't understand what was involved, and seem to have ignored what more educated people have told you. Your question was answered, and additional information was given. You basically said to all the people that took the time to give you extra information (to make life easier for you...) that they wasted their time.
old cars
but all im sayin is ive had it done before but i just want to know if it dose anything to the f22's..
