air coinditioning stinks???
    everytime i turn my a/c on it stinks
    what can i check to see wats goin on?
    I just took my cowl off and found abunch of musty old dirt and decomposed leafs. There probably is some in your evaporator box too.
    wat?
      during normal operation of your a/c system, moisture can accumulate in the duct work and collect on the evaporator core surface. In most circumstances, this moisture is supposed to drain out causing no problems. However, air that enters the passenger compartment of your cb7 contains microscopic contaminants and bacteria that can stick to the moisture on your evap. case.
      If it's humid in your area in the summer time, or if you constantly have the recirc button on, this becomes an ideal environment for mold, bacteria, and odor causing mildew to grow. If this is the case, odor will emit out of your duct work when the a/c is first turned on.
      You can pick up cans of treatment at your local parts store that come with a really long straw. To use this can its like a WD40 gone wild can. You stick the abnormally long straw into the nozzle and stick it as far down into your vent as possible coming in close contact with your evaporator core. It sprays out like a foam in a antimicrobial deodorizer and will ultimately fix your problem. Treatments like this claim to last for up to three years.
      I learned about this last week UNOH FTMFW
        damn.....
        we were on the highway and i was on the phone in her car..
        so we turn the windows up and the ac on..
        and it fucking STINKS!..
        hopefully i can figure out where that DEAD CAT is stuck in her engine bay lol
        Ride: 2002 Lexus IS300
          mine smells like dog pee and cigars, but only when i first turn it full on. so i just keep the window down until its gootencoled
          you'll love my nuts!
            okay thanks guys i think im try and see if any of that fixes the problem.. i hope something works
              A clown farted in there.
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
                yeah if you can remove you glove box and get access to your evaporator, then there might be leaves and other stuff stuck in there that you need to clean out.
                member's ride thread
                91 Accord SE 176k
                  I agree with the others. It sounds like your evaporator. I had a similiar problem in a truck once. It was clogged or just broken all together and it would make a maggot hurl it smelled so bad. Luckily the smell didn't absorb into my headliner or anything.
                    Hi cb7 tuners!!!
                    I have a same problem....
                    tried to use some cleaning stuff and treatments - no results...
                    Any suggestions are welcome!!!!
                    Thanks a lot !!!
                      That or you or the previous owner has/had buddies with a bad sense of humor... From the personal experiences of others, I do NOT recommend any of the following being allowed into the AC/Ventilation system:
                      Deer Urine (stinks, does NOT go away)
                      Mace (burns)
                      Confetti (annoying and one hell of a mess to clean up)
