I Have No Brake Lights
    could it be the switch on the pedal or what? i dont like drivin wit no brake lights its dangerous. help me out..
    check the fuse, make sure its good. It will be in the fuse box under the hood.
    -1992 Accord EX H22 234whp 185wtq
    -1993 Accord EX SOLD
    -1995 Accord EX Wagon Daily Driver
    -2012 GMC Canyon V8 4x4
      didn't see a brake lamp fuse on the fuse box cover
        its dangerous in two ways: you could get rear-ended or pulled over and cited.
          yea i kno..thats why i want help lol
            maybe its a ridiculous coincidence and all of your brake lights burnt out at once.
              doubt it..
              bump for help
                Why not buy some bulbs? They're reasonably inexpensive and really easy to install. At least you can rule it out after you try it.
                  I would go for LingLing's suggestion.
                  If it still does not work , check you brake light sensors on the taillights.
                  1996 Honda Civic LX 2009-2012
                  2012 Kia Optima LX 2012-2013
                    bulbs are fresh
                      it's probably the brake light switch that is located at the top of the brake pedal. they are known for going out and the symptom is that which you describe. later.
                      Avoiding dirt at all costs
                        i had the same problem..the fuse for the brake lights is with the horn fuse....
