I'm sad.... I changed the clutch master and clutch slave cylinders and I still have a dead pedal. Pedal hits da floor. I bled it and everything. Am I missing something. I need help!!!!!!!!
5 speed blues.....
5 speed blues.....
I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!Tags: None
are u using steel braided lines or the hard line?
more than likely theres a leak on either the slave cylinder end or the clutch master end. Where u tighten up the threads usually thats where it leaks. check if theres any fluid near those area's if so then put thread tape on the threads and just retighten and bleed the slave again.
Thanx man.
I've bled plenty of clutch slaves. But I never had this problem.
The clutch master was done perfect. No leaks. What's threads should I check? The threads on the actual clutch slave?I fly by like the coupe grew wings!!!
My coupe!!!
on both ends of the lines goin to the clutch master and slave..i'd put thread tape on em and then tighten em up..it happened to my girls integra it was drivin me nuts cuz the pedal would get stuck to the floor w/out her noticing and she couldn't shift..i found her leak on the side of the clutch master and a lil puddle in the corner of the firewall.
I started 2 bug out! Cuz seeing my car in pain hurts me. Thanx 4 da suggestion man.I fly by like the coupe grew wings!!!
My coupe!!!
Are you sure the piston of the slave cylinder is hitting the clutch fork correctly. I remember when we changed the slave cylinder in my old civic Si we had to take if off and reinstall it twice because the piston missed the clutch fork somehow. Went to bleed the clutch and had the same dead pedal.
are any of your slide pins in the calipers frozen? i just checked my rears when i put new rotors on and the lower slide pins were VERY difficult to move. After I cleaned them up w/ 1000 grit sandpaper lightly rubbing it, then lubed it up, put new pads in. The brake feel changed dramatically.
Originally posted by Losiracer2 View Postare any of your slide pins in the calipers frozen? i just checked my rears when i put new rotors on and the lower slide pins were VERY difficult to move. After I cleaned them up w/ 1000 grit sandpaper lightly rubbing it, then lubed it up, put new pads in. The brake feel changed dramatically.
Originally posted by sunburn View Posttry manually pushing on the clutch fork to make sure that all of the air is out try that it may work
it's what we did to improve my clutch
i am planning on putting new master and slave soon and I will do that again after the master / save is on
By the way, I love your sig!!!!!!!!!!!!!!!!I fly by like the coupe grew wings!!!
My coupe!!!
im having the same problem...
i replaced the master 2 weeks ago and i was still loosing clutch pressure.(having to put in fluid) i bolted up a new slave and i cant bleed the lines by myself, so im waiting for a friend to get here to help me do that. We'll see how it goes...
(i raced autox all weekend, could that be the cause to my problem?)
