Battery Relocation then Bad ABS??
    i relocated a red top optima to the trunk and i have a 4 AWG positive to the distribution block and the 2 AWG ground all the way in the engine compartment. from the DB i have a 0 gauge to the starter, a 4 gauge to the fuse box and from there an 8 gauge to the abs box. It starts ok, but when i press on the brake pedal, my rpms go all the way to 0 and stay there until i let go, the abs light blinks on then off and my stereo also turns off and only comes back on when i let go of the brake. I've tried to use the old battery and put it back in the front but i get the same thing.. Any ideas??
    its has a bad ground
      i forgot to mention. i disconnected the wire to the abs box and i still got the same problem except that the abs light stays on and when i press the brake, the lights go dim on the cluster and everything else i mentioned.
        i replaced the ground from the engine to the motor mount because the first time i started it, it smoked. any other grounds that i should try if that's not the one?
            i got it... it was that one. i replaced it with a 2 gauge from where i have a heatshield for the header to the driver fender. i was getting quite upset because that was only suppose to be a 1hr to 2hr mod and i haven't driven the car for a week. thanks a lot hondaman. i might post some pictures up tommorow.. it looks kinda sloppy right now but it's working. thanks again!
              sorry it took a while. i've been lazy lately. but heres the pics.
              first time posting pics on a forum. hope it's ok...
