Ok, this is a newbie question but i just noticed that my drivers side rear turn signal isn't working. The brake light works but the signal won't flash. On the gauge cluster it shows the left signal flashes but at a rapid rate. The left singal works fine and I already tried switching out the light bulbs. Can anybody tell me how to fix it?
Rear Turn Signal
X2.Originally posted by gaberfb76 View PostI had this same problem and ended up finding a short in the wiring harness. I went to the Honda dealership and got a new one for about $25. Install took about 10 minutes and I haven't had a problem since.
It's a fairly easy fix. Hardest part will probably be finding the short, sometimes they just aren't all that visible.
Another thing you might check is IF you have a 90 or 91, there is a third bulb. It is a little 194 (same as the corner bulbs). It is in the lower outside corner of the outside taillight.
When I first got my CB my taillight filled with water and shorted out my harness. Replaced the harness from the Honda Dealership. Shortly after that, the small bulb burnt out and cause a hyperblink and my Brake Signal light on the cluster was on. Fixed that one little bulb and that fixed it.
might be in the wiring?Originally posted by Eleazar View PostOk, this is a newbie question but i just noticed that my drivers side rear turn signal isn't working. The brake light works but the signal won't flash. On the gauge cluster it shows the left signal flashes but at a rapid rate. The left singal works fine and I already tried switching out the light bulbs. Can anybody tell me how to fix it?Im not an angry driver.....I just LOVE speed!
OHIO CB7'S
