could it be the driveaxle??
    aiit im geting this weird noise from the front ,most likely driver side.its like a squeek...and it does it sometimes when i apply the clutch,it feels like something might be loose or really worn,and if i go over some bumpy road it starts to feel like its bouncy/loose, when i apply the brakes at times i feel like something is movin foward and back by the driver side like under the car..my driveaxle already clicks at turns n i think it might be completely gone could this be it???
    Taking it one day at a time since my cb got stolen and stripped of my mods..
    check the boots on your driveshafts. they normally make a clunking noise when you turn. my front end felt really loose going over bumps on the highway. i replaced the sway bar end links and it fixed it.
    WINTER = HONDA UPRAGES - Last year was a HUGE suspension upgrade. This year its cockpit upgrades, brakes, wheels, and a possible tune and/or motor swap.
      aiit thanx,yea ima check out all the things under the car soon..
        either axle or could be a lot of things that could come loose.
          Yo there is a torsion bar that goes forward from both front wheels or hubs whatever but mine was loose and caused this crazy noise if I took off real quick or stopped fast so you can check that just look under your car in front and if you still have the plastic black cover then use 10mm socket and remove that and look on the beam that goes accross, it runs thru there its worth a look. good luck finding the prob if not.
