Bleeder Valve Broke
    Bleeder Valve Broke
    Bleeder Valve Broke.. Went to undo the front left calipers bleeder valve and the top snapped off.. now I have a stud sticking out. I can't extract it myself.. I've tried and just stripped it bad. Will a standard brake shop fix this? and how much do you think they'll charge?
    better off going to the parts store and buying a remanned caliper.
      dude thats the worst eh... did the same thing on my 3g... everything was done , new master cylinder, last wheel to bleed and SNAP. AHHHHH!
      i ended up replacing the entire caliper... only ended up costing about 60 bucks i believe. shitty, but not the end of the world. i suspect a brake shop would do the same, since that metal is pretty soft and gets mangled up easy
      RIP
      Bought from : LosiRacer2, h22anow
        once thats seized in there, its SEIZED in there... usually a good sign that the caliper is pretty significantly corroded and by the time you somehow drilled and tapped the old remains out, you might as well just get a new reman caliper.
