problems starting
    problems starting
    tried to start my 92 accord wagon with the f22. it just cranked and cranked. let it sit for a second and tried again. all it did was crank. let it sit and tried a third time. cranked for a second then started. ran rough for a second then ran fine. any ideas?
    sounds like main relay. check and see if the engine light stays on after try to start it.
    thats what mine did when my main relay went...
    "I remember u and I, parked on lovers lane, Drinking each others blood, so young and insane"
      vaccum line maybe?or fuel pump maybe???
        maybe it was a hiccup or something. started fine and drove fine when i went to work. when i got off it started almost instantly and ran just as good as it always has. im gona do some general maintenance next oil change. plugs, wires, air filter, fuel filter and anything else i can think of. probably clean the throttle body. the car has 225k miles on it so im not doing any major fixes.
          why, it cranks no start....
          check if u got spark, very easy...if you do concider the main relay...there is a diag in the tech section for this.
          Retro!
          Hater
            my prelude did something simaler today cranked it over it would start for a second then die did it several times as i tried to start it after I pushed it back into a parking place tried it again and it started up fine it was weird going to give it a full tune up real soon
            needing a new project got rid of bagged S10 going back to Honda's
