SiR-T F20b??
    SiR-T F20b??
    Some one said that they were doing a SiR-T F20b swap. I have never heard of a SiR-T. What model and year is that engine from, and what does the T stand for in the SiR-T? I believe it is JDM.
    Thanks
    Its out of a CF4 Accord I believe (JDM 6th gen)
    wat?
      Last i knew, T = Turbo.
      Originally posted by Jarrett
        You FAIL
        Only OEM turbo honda I know Is the K20A1 out of MDX
        wat?
          I dont have to listen to these wild allegations!!
            wow, you guys are fast on the responce side of things.
            And ya, the MDX is the only Honda that came with a turbo from factory. So, that can't be it.
            Anyone else want to take a stab at it?
              The T stands for TipTronic I believe
              wat?
                except for the hondajet
                that came with twin turbos.
                峠 で ドリフト を して 下さい。
                steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
                  Originally posted by C91BLX7 View Post
                  You FAIL
                  There are some models that never made it here.
                  JDM G1 Honda Legend came turbo on certain special models
                  JDM Honda City comes turbo (weirder small mini-cooperish sized civic looking vehicle)
                  JDM Honda Dunk is turbo (something honda should bring over here to kick Scions XBs Ass...especially the mugen version)
                  The "T" stands for Tourer. Like the JDM CB Si-T model is called the Sport Tourer in jdm brochures.
                  I need a custom turbo manifold built....
                  707 NorCal NinjaZ
                  Honda Twincam Motorwerkz?
                  "I am the Yakuza CB7!"
                  '92 Accord Sedan SiR
                    You FAIL
                    Who fails, now??
                      Thanks Kurobei,
                      I personally saw a Honda City while I was in China last year. Never got to look under the hood though. I didn't know they were turbo!!
                      So, my next question is about "TipTronic". What is it?
                        You FAIL
                        mdx= v6
                        RDX= k20 turbo
                        92ex coupe h22
                        93 240sx with silvia front end (kadet in the works)
                        http://www.cb7tuner.com/vbb/showthre...=1#post1894990
                          Originally posted by DaGrk1 View Post
                          mdx= v6
                          RDX= k20 turbo
                          yeah i got them mixed up
                          wat?
                            Pic of Tiptronic shifter-->
                            Easiest way to explain (taken from wikipedia):
                            A Tiptronic transmission can operate in the same manner as a conventional type of automatic transmission, but the "Tiptronic" mode also allows the driver an additional method of manually overriding the automatic shift changes, by moving the shift lever into a second "Tiptronic" shift gate, equipped with two spring-loaded positions: "upshift" and "downshift". Once the lever is in this gate, the driver takes over most of the gear shifting decisions, which would ordinarily be performed by the transmission's computer, permitting, for example, the delaying of an upshift for increased acceleration, or to increase the effect of the engine braking.
                            3 CB's gone....
                            1 WK Overland....
                            Still miss the CB though......maybe one day.
                              it happens
                              92ex coupe h22
