Brake lamp light
    Brake lamp light
    Wierd, all of sudden the brake lamp light on the main gauges now appears everytime i drive! When i turn the car on, its not there, but as soon as i apply pressure to the brakes it lights up
    any idea whats wrong, or is it trying to send me a signal or some wiring loose?
    I installed carbon fiber tail lights back in '04 and mine does the same exact thing but no need to worry since I've never had anything go wrong because of it, kind of annoying though.
    Still hustlin that Old Skool.......it never ends.
    vv My Member's Ride Thread vv
    http://www.cb7tuner.com/vbb/showthread.php?t=123371
      OH i know......same thing happens to me...nothing bad happens though(thank god)
      STUFF FOR SALE!!!
      1992 Accord Lx.
      1992 Accord Ex.(SOLD)
        To be on the safe side I would check your taillight wiring and bulbs. It would suck if you got popped for a taillight out due to a loose connection.
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
          Mine does that also, all lights work 100% and are correct bulbs
          Ignore it
          90 accord EX automatic F22A4 232,500
          DIY ram intake
          0gauge/4gauge BIG 3
          stock alt rewound to 120amps
          optima orange top 830cca 1030ca
          fully synthetic valvoline "Max Life" 5w30
          Other rides:
          2004 Jeep Liberty v6
          2001 Honda civic ex coupe 1.7 vtec
            yea, just ignore it.
              lol ya it seems harmless...but its sooooooooo annoying lol
                annoying isn't the word !
                  seems to be a preety common problem. just and update i havent gotten a chance to check the tail light wires but i do have aftermarket tail lights and the brake lamp light comes on and off when it feels like it.
                    I have the same fricking problem and I can't ignore it. It is so f***ing annoying. I chopped off a plug that look more than dirty since I couldn't clean it and replace it but it still persists. All my lights work just fine too. It's only when I turn the car on and press on the brake pedal that it goes on. Sometimes, very rarely it won't go on. What is it seriously?
                    NEW MYRIDE THREAD
                    PARTS 4 SALE
                      malfunctioning brake light switch?
                      1996 Honda Civic LX 2009-2012
                      2012 Kia Optima LX 2012-2013
                        If you are that annoyed by that....DISABLE IT.
                        There is a brown box on the driver's side tail light, there is a wiring harness coming OUT of it. Find the WHITE wire with a GREEN stripe on it. Now becareful not to get a green wire with the white strip on it, b/c those are not the correct wires.
                        Anyway, solid WHITE WIRE with GREEN STRIPE, cut it, and extend it(aka use a butt "connector" to add more wire, I used 14gauge so it is longer), and GROUND IT. I just grounded it to one of the 4 bolts that hold in the taillights.
                        IT WILL BY-PASS THE "BRAKE LAMP" INDICATOR check so it never comes on again.
                        CREDIT FOR THIS FIX goes to : cp[mike] as he mentioned it in another thread and it works perfectly.
                        DIY ram intake
                        0gauge/4gauge BIG 3
                        Other rides:
                          a while back like 3 months ago some fuck busted my driver side taillight and it still lit up he just busted the plastic piece and my brake light on my cluster came on everytime i drove too but it randomly went off on its own idk if it just eventually burnt out on the cluster or what but i havent replaced my taillight yet cause im broke lol but anyone got an idea why mine randomly went out on the cluster??
                          to achieve a Fuck, you must first give a Fuck
                          Follow me on twitter @tru_whitetrash
                            Strange but true. A few weeks ago I threw my dogs chain leash in between my front seats. Part of it went into the cover of the hand brake. For two days I drove around with the brake like poppin on and going off, sometimes falshing rapidly when I hit a bump. I checked the brake handle to make sure it was all the way down. It was so thats why my lazy as didnt just pick the chain up when this was going on. Next day, smae thing. I pulled the chain outta there and it hasn't done it since. I haven't pulled the panel up to see what kind of park brake switch is in there, but it may be worth looking into.
                            My inferiority complex isn't as good as yours.
