94-97 manual transmision
    i found a real good deal on a 94 honda accord ex 5 spd tranny hes selling everything in the deal i was just wondering if that is the same tranny that is in or cars or is there any differences
    Nah, they are different, I actually like those trannies better than the stock f22 tranny. Is there something wrong with your current tranny? Manual conversion?
      What's diff from our trannies to the 94 ex trans is that the 5th gens have shorter gears
      Ill take the 94 tranny if I was u, she bolts up to our motors jus have 2 drill and retap the tranny mount, the 94 trans, and the h23 have smiliar gearin!
        i was interested in a manual swap and i found one with everything including the ecu will the ecu work with my car the guy only want 250 for everything that i need off of his car
          The ECU won't do a thing for you, but the transmission will work. You may have to tap a hole, as f20a cb7 said above. You'll also need to do the regular auto to manual conversion.
            what ecu would be an upgrade from my factor one or could i get my factor one chipped
              what engine do you have now?
              p12 if you have the F22A1 or A4
              and pt6 if you have the A6.
                i have a f22a6
                  would you have to tap in a hole if you already have a manual, doin the f22b, or h23 trani swap?
                  1990 accord LX-Laurel Blue
                  predator intake/OBX header,down pipe and resonator
                  tune up-belts,gaskets,fluids
                  17" rims and tires
