front mount trouble
    front mount trouble
    ever since i put a prelude mount on h22 5speed tranny...my front mount by tha raditior does not line up any help????
      CAN ANY 1 help motor run REAL ROUGH!!!!!!!!!!!!!!!!!!
        You're using a Prelude mount on an Accord? That's your problem.
        Did you tap a hole in the tranny, or are you using the stock mounting points?
          I BELIVE I'M USEING THA STOCK POINTS IS THAT BAD.......whaT can i ASK a SHOP 2 FIX mY problem
            Yeah, the motor doesn't sit correctly with the stock points, and it will destroy your axles (and possibly your transmission).
            You need to use the Accord mount, and tap one hole in the transmission to do so. There is a thread about it in the Swaps section.
              when i had my accord mounts i dident tap it.....and then i broke 1or 2 bolts inside the tranny...thats why i had 2 use a prelude tranny mount
                anY help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
                  YOU HAVE TO tap the holes in the transmission for it to work
                  1990 accord Honda-Challenge, H22 powered
                  newer race video,older race videos
                  1991 accord parked, parts and back up shell
                  1993 accord acquired 6-11-16
