Engine Build
    Engine Build
    I Was Wondering What Kind Of Power Would I Make If I Use A F22 Block A H22 Head And F23 Intake Mainfold? Will Horsepower Be Big Numbers ?
    thatll vary for alot of reasons dude. but one way or the other its not gunna be like 200hp
    93 Accord LX Sedan (sold)
      Why would you do that? If you are thinking about using a stock f22 block, then no it will not make big horsepower, less than a stock H22.
        a lot of people will tell you that frankenstein motors will not last very long. the f22 bottom end may not be able to handle the high rpms the a real h22 bottom can handle.
          i can attest to that !
          overbored s/b chevs that last 3 races.
          a supercharged 5.0 stang that blew partway down the street!!
          go for a built H22 more bang for the buck !
            F22 bottom end = much lower compression than the H22
            F23 intake manifold = inferior to the H22 (and it may not bolt up to the head)
            That's just a lot of work to build something less than a plain old H22.
