Hey,
I'm new here... hopefully I can get some help from someone on this.
I have a 1992 Accord LX 5MT with 210,110 miles. The engine was replaced at about 120,000 mi after the guy who owned it before me threw a rod through the block. I don't know the engine type as it has no stamp. I assume that it was replaced with either an F22A1 or F22A4 as the stock intake mani had no bypass valves on it.
Anyways.
Just changed the timing belt/balancer shafts belt and replaced the pulleys associated with them. Had trouble getting it started, turned out i didn't have the PGM ground connected to the body. Originally, I thought I had incorrectly timed it, so I removed the head to check for valve damage. There was no damage, so I polished the bottom of the head and replaced the Head Gasket and the Exhaust Mani gasket. Since I had the intake mani off, I decided to do the F22A6 intake mani swap. I headed over to the junkyard and picked one up for 22 bucks. Also picked up PT6 computer to replace the stock PT3 so I could run the intake manifold valves. Replaced gaskets, installed manifold, ran vacuum lines and wired up IAB box on the bottom of the mani to the computer and dizzy. Then I put everything else back together.
Started the car. First thing I noticed was an unusually high cool idle ~2000 rpm. Allowed to run a bit longer to reach warm idle where it settled at 1100 rpm (still too high). The car then started eratically idling between 1100-2000 rpm. Checked all vacuum connections and they were good. CEL came on shortly afterwards. Pulled codes and got 12 and 14- EGR Lift Valve Circuit malfunction and IACV circuit malfunction.
Eh, EGR valve code was a fluke, the connector on the EGR valve was loose. Fixed.
IACV is still a problem. When it is connected, the car idles erratically between 1100-2000 rpm. When disconnected, the car either sits at a smooth idle around 1200 rpm or jumps quickly between 1100-1200 rpm.
Voltage to IACV is about 14.93 volts
. IACV reads resistance at 0.01 ohms. Voltage at battery is around 14.93 volts
. The IACV is getting coolant. I've tried two different IACVs with no luck.
Very weird stuff going on here. Does anyone have any idea what the problem is?
Thanks,
Sean
OrangeAccord
Anyways.
. The IACV is getting coolant. I've tried two different IACVs with no luck.Very weird stuff going on here. Does anyone have any idea what the problem is?
Thanks,
Sean
OrangeAccord
