changing o2 sensor?
    changing o2 sensor?
    How hard is it to change the o2 sensor?
    I kept thinking they were crazy expensive, but I see cb7 DENSO(which i guess is OEM) for less then 60 shipped.
    Pretty sure the o2 on my car is the original, although i have no CEL's I'm still thinking replacing it might help gas mileage. IDEAS?
    90 accord EX automatic F22A4 232,500
    DIY ram intake
    0gauge/4gauge BIG 3
    stock alt rewound to 120amps
    optima orange top 830cca 1030ca
    fully synthetic valvoline "Max Life" 5w30
    Other rides:
    2004 Jeep Liberty v6
    2001 Honda civic ex coupe 1.7 vtec
    its not hard to change. you can get a o2 senor socket or use a wrench about a 15min job
    '90 Accord EX
      they sell the socket at ur nearest auto parts store. tell them you need the o2 socket and use it. it'll be a breeze tho.
      Member's Ride Thread
      Don't forget to cut holes in the box. Someone sent me a dead hooker one time, and that wasn't cool.
      Bought From: AccordWarrior | CB7lx91 | DarkShadow707| Tn_Accords | H23CB7 | Jack_lee | Fatboy1185
      Sold/Gave To: 90goldcoupe | CB7lx91 | Jas_r34 | F20accordturbo | BatmannamtaB
        INFO or a DIY link?
        Where is it located?
        What do I need to remove?
        DIY ram intake
        0gauge/4gauge BIG 3
        Other rides:
          Since you have an EX its under the car
          '90 Accord EX
            ur o2 sensor is located behind your heatshield. you'll have to take it off and then it'll be in plain sight but it might be visible with it on. IDK because mines isnt on anymore. but its on your header.
            or where he said.
              since you have an EX, i believe yours will be under your car on the downpipe. for me, i didnt even need the O2 socket. i just used a crescent wrench. hopefully yours hasn't seized onto the downpipe.
                Originally posted by 90Haccord View Post
                IDEAS?
                Don't replace a working part.
                Spend the $60 on personal satisfaction, whatever that means to you. Could be window tinting, a bag of weed, cheap rimjob, whatever.
                Peace.
                - Ghosty
                WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
                FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
                  Its the original o2 from 1990.
                  Just because its not throwing a CEL doesn't mean it isn't lazy.
                  My timing belt is just fine also until it breaks
                  DIY ram intake
                  0gauge/4gauge BIG 3
                  Other rides:
                    yea the o2 sensor is located on the back end of ur downpipe where the 2 pipes become one. most likely on top of the pipe.
                    my o2 sensor siezed up on me and i just left it alone until i did my motor swap.
                    o2 sensors arent hard to change at all unless it siezed which u can unplug the o2 sensor, take the downpipe off and soak the o2 sensor in wd40 or pb blaster until u are able to unscrew it.
                    make sure u let the engine, and exhaust cool down
