so on my way to work today i was passin a car and noticed when i dropped down to 3rd between 4500 and 5000rpm it hesitated my rpm needle stopped to then it just shot up like normal acceleration..can anyone help me?
engine hesitates
egr isnt activated at those rpms.Originally posted by orangeaccord View PostCould be an EGR malfunction of some kind. Also possible that there's a vaccum leak the needle on the tach is jumping around.
make sure you don't have the infamous red dust in your distributor. if you do that means the bearings in the distributor are screwed. my car did that in the winter when i was delivering pizzas lol. it started out as hesitations, then went to feeling like the timing was REALLY off, then went to seeming like i broke the timing belt. new distributor solved everything... it was like $50 at the wreckers. i'm pretty sure that was mainly a problem with external coil distributors though... correct me if i'm wrong.
just something else to have a look at when you're doing your tune-up.Last edited by demortey@mac.co; 08-30-2008, 02:22 AM.
