ok so i can get a cl1 (2000) accord euro-r h22a obd2 engine for $1500. my question is am i better off buying the CL1 engine for a swap seeing as tho its so cheap? or do i stick with the obd1 in the 92-96 h22a? i wont be boosting the engine, just adding CAI, exhaust, headers etc. strictly no turbo. the CL1 engine has approximately 64300km and has a hole in the oil pan. not sure how easy it is to get a new oil pan, shouldnt be an issue im guessing...
92-96 h22a vs. CL1 Accord Euro-R h22a
Originally posted by jacobuchanan140 View Postengine and trans?
the extra money usually isnt worth the performance but if you can get the combo for that cheap do it
I'd go for it, and just deal with the OBD2 to OBD1 conversion...
However, the hole in the oil pan concerns me. Engines with a hole in the pan are often run with low oil pressure... the hole doesn't usually appear when the engine is off... Therefore, it may be damaged.
If it's worth the risk, or you KNOW that it's not damaged, then go for the Euro R.
Originally posted by deevergote. View PostI'd go for it, and just deal with the OBD2 to OBD1 conversion...
the engine is fine. its been tested and says its fine. my only issue would be that hole in the oil pan....can i get a new oil pan for it? are they repairable?
