Gear ratio differences between sedan & wagon?
    i have a 91 wagon ex-r f22a6, automatic. i need to rebuild my transmission but would like to know if the wagon had a different final drive ratio or any gear ratio change. if is different i will be rebuilding the original thats under the bench. if not i have one in better shape to rebuild.
    96 Accord SiR driveline installed. CF2 donar
    I think it is. it would explain the 140mph speedo
    93 Accord LX Sedan (sold)
      that must be different in the us cause all the canadaian ones so far seem to be 220 and thats 2dr, 4dr and wagons. what does a 2dr or 4dr have in the us,160mph? the reason is when i replaced the original transmission with the used unit i noticed 1500 to 2000 rpm difference at about 110 kmh . it used to run about 3100 now its under 3000 for sure. the original transmission was going into lockup
        I know there's a difference on the manual tranny. The brakes on the wagon are bigger too. I think it has to do with the fact that the wagon is heavier.
        Originally posted by lordoja
          dammit, a wagon just arrived in the junkyard when i was there today. coulda stole the front brake setup.
            so i wonder if nissin brakes on a wagon are larger than nissin style on a sedan. i denfinatly like the sedan transmission due to lower rpm at highway speed. does anyone know the final drive ratios?
              The wagon brake setup is larger than any Sedan/Coupe CB7 setup.
              As to the final drive ratios, I haven't the foggiest.
              Perhaps go out and find out the transmission code (Stamped on the actual transmission) and then search it.
              Originally posted by Maple50175
              Oh here we go again. Maples other half.
                wow i can't belive i looked past that... umm embarassing considering i'm a transmission rebuilder by trade. accually i'll get the numbers decoded by honda in the next couple days, good idea thanks
                  honda won't tell me squawt so i'll post the info when i disassemble both
