d4 light flashes vehilce only cranks will not start
    i have a major problem that happends off and on sometimes when i go to start my car the d4 light blinks and the car only cranks and will not start have to wait a while and keep turning the car on to see if the d4 light blinks i checked the codes it said something bout the shift solenoids any one have problems like dis ?
    BK ALL DAY
    It is the main relay. You will have to get a new one. I had the same problem with my automatic on hot days. New main relay fix the problem and has never done it since.
    -1991 Honda Accord LX H22a-
      i have the same problem. i let the main relay hang and tap it a couple of times to get it going.
      92ex coupe h22
      93 240sx with silvia front end (kadet in the works)
      http://www.cb7tuner.com/vbb/showthre...=1#post1894990
        what if i have a couple tranny codes would the main relay solve that to ?
        BK ALL DAY
          You may have 2 birds for one stone.
          You can check your relay at the top of the interior fuse box. Right aftet you remove the CC box , the main relay will be exposed. Take of the relay and check for any cracks or burned points.
          If there is present , resolder or get another relay.
          If that solves everything , you tranny shift solenoids should be checked as well , they might be just dirty enough to get it malfunction.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            ight cool thanks
            BK ALL DAY
              When my car wouldn't start because of the main relay it threw some solenoid codes and a tps code maybe a couple more. I Tried replacing the solenoids on the front of the tranny first. That didn't fix it a new main relay fix it. And if you tap it it does fix it for a little while.
