As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Left High Beam socket dead?
    im trying to figure out why my left high beam socket won't work.
    when my lows are on the high beam socket that doesn't work reads 12v, but as soon as i trigger the high the voltage drops to 0.
    the right one lights up as it should.
    if it makes a difference im running an hid kit for my lows.
    any help appreciated. thanks.
    hey it sounds like your daytime running light module. this is very common, you can cheat and hard wire high beam signal at the drl module( there is one for each high beam) so it will turn on both. the right way would be to replace the module
    96 Accord SiR driveline installed. CF2 donar
      Any chance you have a diagram to show what wires need to be rewired to cheat it?
      Thanx
        yeah i 'll scare that up, how do i send it to you
          sorry i can't find the original that i had and our computer is down at work so i'll post it as soon as things are repaired at work
