what year distrubitors can fit on our cars from the prelude ?
prelude distrubitor
your stock is good till like 300HP. just check it to see if its still all working like it should
93 Accord LX Sedan (sold)
You will need a distributor off of/for an H22A. The Accord one will absolutely NOT work. A dizzy from a 93-95 Prelude SIVTEC is pretty much your only option. Anything 1996 and up is OBDII, and will not work (unless you are converting everything to OBDII).Originally posted by lowproki View PostSo i can use my stock accord distrubitor on the H22 engine?
Im doing the swap right now so i need help i been reading all your faqs and stickies nice info.
Be sure to check if you need an internal coil or an external coil dizzy before you get one. You can save yourself some wiring if you get the right style in the first place.Last edited by benji; 10-21-2008, 03:21 AM.1992 Prelude S w/swapped H22A
Then you need an internal coil distributor for an H22A. I think it's a TD60U distributor. Just look around on ebay for an internal coil distributor off of a 93-95 H22A. Or get one from a parts place. Don't know what else to tell you other than that.Originally posted by lowproki View PostWhich one is the internal coil i have internal1992 Prelude S w/swapped H22A
yeah you can. I ran like that for a whileOriginally posted by lowproki View PostAlso i can turn on the car with the stock accord ECU right because i haven't been able to locate a H22 ECU
if your CB is a 90-91, yes. if its the 92-93, youll need the H23 oneOriginally posted by lowproki View PostAlso i can turn on the car with the stock accord ECU right because i haven't been able to locate a H22 ECU
okay cool thanks u guys are to helpful lol......... way better help than other forums were they just post search but when u search for answers all u find is other threads that say search to lol....... not here u guys actually help..
Ohhh i don't now why im not able to go into the classifieds i never got an email in my email adress maybe my account is not activated yet.
Im looking for a throttle body H22 TPS is broken and i think i have to change the whole throttle body since its not screw on.
Or how can i change it i see ebay salling the TPS for its selfLast edited by lowproki; 10-22-2008, 03:51 AM.
