heater hose
    heater hose
    my 1990 accord is having a problem with the anti-freeze i fill up the hole thing and when i drive around for a few hours its completely dry i know its a leak but im stumped i cant find it or even tell where its coming from im wondering if its a heater hose problem or can it be something else
    Well, if you don't see any obvious leak then you probably have a blown head gasket or a cracked head, and it's all going out the tail pipe.
    Pull all of your sparkplugs and see if any of them have a greenish tint on the end. If you've been combusting antifreeze, then you will see it. Or do a compression test if you have a gauge.
    1992 Prelude S w/swapped H22A
      If its burning that much coolant it would run like utter ass and smoke about as much as a train in the 1920's.
      -1991 Honda Accord LX H22a-
        ok so yes the leak is obvious its on the upper right side close to the driver side im tryna figure out where is the heater hose located on that side because i believe that is whats leaking, do you know or does anyone have a picture of where the heater hose located in these cb7 accords
          Listen dickhead just take it to a shop and have it fixed cause even if you find were its at your not going to fix it
          Have a nice day
          Links to my rides :
          1992 Accord EX*
          1990 Accord EX
          1991 Accord SE (4th)
          1991 Accord SE (3rd)
          1991 Accord SE (2ND)
          1991 Accord SE
            Insults arent going to help this guy out.
            "Brought to you by Carls Jr."
              Lmao it just might help, this dickhead thinks he can do this himself when he really knows he can't ...lol.... I say this cause I know him and was looking to see what hose it might be and could not find it cause its a bitch and I told him he's better off going to a shop and have it done
              Links to my rides :
              1992 Accord EX*
              1990 Accord EX
              1991 Accord SE
                ouch!
                but if he does try to fix it himself at least he can learn how to do it himself!
                Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
                rock her with the shocker!
                  Originally posted by civickiller View Post
                  ouch!
                  I hear you on doing it your self but when you live in NYC and not that many tools it worth just having it done by a shop. it should be no more than $60 with parts included
                  also he wanted to change his oil himself rather than pay $23 to have it done...lmao
                  Links to my rides :
                  1992 Accord EX*
                  1990 Accord EX
                  1991 Accord SE
                    http://www.hondaautomotiveparts.com/...y5=WATER+VALVE
                    It's probably one of those (goes to your heater inside the car)
                      These guys that they pay to change oil all day at these quick lube places really dont have much experience. I have heard of them leaving pan plugs loose or not properly tightening filters. I do all my own work because I dont trust others. But im a diesel mechanic so its only natural for me to not want to pay others to do what I can do and have piece of mind knowing that its right.
                        yeah shops suck. they forgot to tighten my mom's drainplug in her van RIGHT before she went on a 1500 mile trip. ASSHOLES. Thats why I do my own shit.
                        Btw, if you did the HG yourself.....if it is a headgasket. You can save yourself about 1200 dollars. I did mine for about 600 give or take, including a 3 angle valve job w/ machining and pressure test done at a machine shop. Honda wanted 1400 to just put a new HG in and machine the head. So yeah, DIY work REALLY saves coin. This was my first HG I've ever done btw.
                        member's ride thread
                        91 Accord SE 176k
                          I had the same problem. The hose it goes inside the firewall on the back of the engine, right there under, way under the intake manifold. the picture benji put on is the right one. I live in florida. I don't need it. So I Bridge cap it. You, in opposite live in New York! Get it fixed properly on a real mechanic. Or do it yourself. You might fix it. I can guarantee a lot of aggravation but you will never learn if you don't try.
                          My tip: don't go straight to the hose, work on the parts around and make some space to work. Obviously, work on it when your car have cold engine.
                          Barrabas !!!
                          Short ram intake, rasonator, muffler change and 4-2-1 exaust for $25 from the Junky, arospeed coilover springs and ex-jarhead gold 15th Anniversary rims. More mods to come soon !
                            The same thing was happening to me. it would ownly happen when the radiator was under pressure. it turns out that it was the top hose.
                            So chek it out
