Question????
    Question????
    I Was Drivin One Night I Was At Least goin 15 And My Timing Belt Poped..i Thought It Was Gas Cuz I Was On Empty.. So I Tryed Starting It Over And Over.....Is The Motor No Good. Or It Can Be Fix? Let Me Know ASAP!!
    You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
    what do you mean your timing belt poped
    it snapped ?
    -->751 whp @ 27psi <--...Midnight Tuning <----
      Just because the car stalled it doesn't mean it was the timing belt.
      1993 Accord EX
      2011 Subaru STi
        if you were driving and the t-belt no longer turned the cam and crank together as it is supposed to...via snap, pop, slip, lock...then then only way to determine if the engine is good is to do a leak test, compression check...if no good...follow with a measure of the valves. That will tell you if you 'doinked' a valve.
        Most likely though, if the belt failed while driving the valves are bent. In this case, unless you plan to rebuild the engine for higher performance, it would be cheaper/simpler to get a working junk yard motor...or swap an h22.
        ____
          Pull the valve cover and rotate the engine to see if the cam is still turning. No turn means no good.
          "Brought to you by Carls Jr."
            i had this happen to me too... i bent some valves, i got the valves redone for $300 but was stupid cuz a few months later my whole motor went BOOM and i bought a whole working motor of some kid for $100...
            if you indeed bent the valves than u may just, like posted above, by a new working motor...
            or time for an H22
              an h22 can be bought for around $400 area used...well at some junk yards...vs pistons, valves, grind, other parts...bumped up compression means new piston rings...etc etc...or ...400 for an h22.
              ____
                ya but how much will it total to do do the conversion?
                91 ex sedan
                And now, new for 2012, a 93 ex wagon!
                Paypal verified
                Bought from: frootloops, 90accords, Agol
                sold to: Agol
                  I've seen people quote some...extreme numbers. The ecu may add 40, the wiring harness...not sure...beauty of honda's, their electrical connectors are usually the same (among same year model).
                  BUT I need to emphasize that I can't really give an est. as I haven't done an est. myself for this swap. I'm going off of what it would cost for me to get a used motor in good shape, ecu, mounts, wiring harness, and ecu. The stock tranny can be utilized...and you know a h22 with 100k miles is still in good shape so a rebuild of the h MAY not be necessary. If I were more serious about said swap I would know more about actual cost. My actual cost will be parts only as I can do ALL the work myself...from actual drop to soldering to custom mounts.
                  Since I haven't done (looked into) it and seen what "other" issue will come up I really can't give you an idea...sorry...just going off parts I have priced in the past.
                  problem with rebuilding an old motor though...you're going to run into many problems (time to get it finished will be LONG as well) associated with rebuild of an old engine. Being the good 'ol f22 they won't be as bad as other cars...but still.
                  IMO, if it were me (I've always said if the f goes I'm swapping an H) I would swap in an h. But I would price it out based the OP's skill level with mechanics and customization. But again, I honestly can't tell you how much a swap is.
                  ____
                    figure @ $2500 to 3k for a total conversion, that is taking into account getting a low mileage JDM H22 with trans,axles,harness and ECU. and labor installing it at a reputable shop that knows what they're doing.
                    $725 now in the bank for my swap (worked this morning driving a box van up to Saugerties filled with furniture, didn't have to unload it thank God!)
