transmision swap for my 90 lx
    so you may have read in another thread that i just found out that my sincros are going out and im thinking bout doing a swap instead of the rebuild. so here are my questions.....
    i found a couple h23's already, i read in another thread that id have to dril and retap the mount, i saw this for the guys auto, and mine is a manual, do i need to do the same...
    what other trani's would work? what year cars for those and h23?
    1990 accord LX-Laurel Blue
    predator intake/OBX header,down pipe and resonator
    tune up-belts,gaskets,fluids
    17" rims and tires
    yes you would need to tap and drill the 2 holes.unless you got the mount from http://explicitspeedperformance.net/MMK.html
    92ex coupe h22
    93 240sx with silvia front end (kadet in the works)
    http://www.cb7tuner.com/vbb/showthre...=1#post1894990
      Drilling and tapping is the least of your worrys, its not difficult. You can run onto mount issues that could cause enough of a misallignment that your axles will clunk while turning or break. Read the sticky about this swap a couple of times. If you can come up with the green for the explicit speed bushings they make for a super clean straight install.
      "Brought to you by Carls Jr."
        hey guys sry for the delay i have been with out power or work since the hurricane hit so its gonna take me a while to get to where i need to be. as soon as im able to start this project ill let you know....
        17" rims and tires
          There's a diy on here for h23 swap. I forgot where its @, but its here.
            i know..it had mentioned that it was for an automatic swap i just wanted to know if it was the same for my manual
            17" rims and tires
              ok so asuming i have the cash and all that. is it possible to do it myself? i got just basic jack stands and cherry picker, would i have enough room to drop it from the bottom? or what about stripping it down, towning (its free for me with AAA) having them swap it, then have them put in the trani,bushings, and taping the mount(if i dont find the lude mounts). then tow it back and put everything back on. would it be the same price to just have someone do everything?
              -i know that alot to ask but would rather do it myself as just want to be able to have the experience and say i did it you know....
              17" rims and tires
                -its not lowered at all by the way...
                17" rims and tires
                  um... what?
                  17" rims and tires
                    how does that help me?
                    17" rims and tires
                      bump....
                      17" rims and tires
                        when i had my cd5 tranny put in two guys did it and they had a lift and yeah they dropped out the bottem... it will just take you a lil longer to do it by ur self. i dont think it would cost the same to have someone else do it cause they'll charge you for everything.
                        Freedom Is Not Free
                        U.S Army 02/08 Medically Discharged
                          so it is possible to do it without a lift, just a cherry picker?
                          17" rims and tires
                            bump again.... sry , need to know...
                            17" rims and tires
                              i figured i could just undo everything and then drop it underneath the car. then using a jack, raise it back up to the car with the new tranny.
