92 lx. My cruise control don't work. I've checked fuse,connection. Where does that rubber tube go to? is there a quick way to test to see if the c.c. "thing" works?
c.c. don't work...
Originally posted by sc2dave View Post92 lx. My cruise control don't work. I've checked fuse,connection. Where does that rubber tube go to? is there a quick way to test to see if the c.c. "thing" works?
post some pics or something.
rubber tube. AKA vacuum line could be one a few that are involved with the CC system.
and the CC 'thing'?
which 'thing'?
the switch? the vac. chamber? the CC controller?
be more specific bro.
we are all happy to help but we need a little clarity.
that hose is supposed to go exactly where it's going, right out that hole. Is the vacuum hose on the back of it alright? Check it, and the fitting to make sure they are in good shape. Also unplug the vacuum hose and check to make sure it's drawing vacuum alright, it will be obvious because the idle will fluctuate. Look on the actuator, there's a little electrical plug that goes to the actuator, make sure it's plugged in all the way, and disconnect it and check the plug and socket for any defects, and make sure the wire looks alright. If you wanted to get in depth, you could break out a multimeter and test voltages when you hit set/resume and stuff and see if the wire has continuity. Hit the switch for the cruise control, make sure its lighting up ok. Also check the fuse on the inside kick panel, right by the driver's side door. It's hard to see and get to, but there's the little diagram on the inside of the door to help you locate the fuse.
If you check that, and it all seems to work, than chances are that your actuator is bad. Ask someone around here for one, or check the junkyard, the vacuum barb on my actuator was broken off, so i just got a new actuator for 25 dollars and all of my cruise control problems went away.Cars:
91 Accord LX Sedan (sold)
98 Accord LX Sedan
95 Eagle Talon TSI AWD (E3 16G, PTE 780cc, Godspeed FMIC)
Originally posted by rcdreamer View PostDoes the light come on in the gauges when you try to enable it and it just doesn't hold speed?
Stupid question, but did you make sure the crusie control button to the left of the steering wheel is on?
alone in this game . ::My Ride My Way::
Originally posted by tear2wo View PostWhen I press my cruise control the light turns on but it doesn't hold speed. It worked a few weeks ago. Wat could it b?
Also check the cable between the throttle body and the cruise control actuator to see if it is seized or broken.
