Engine Vibration
    Engine Vibration
    In my accord my engine vibrates randomly at different rpms , i have replaced the motor mounts and it didn't seem to help a whole lot, but it help a little. It seems to vibrate alot when i floor it in second and third, and some in first. It does it worse sometimes than others would anyone have any ideas on what the problem could be
    Have You Checked Your Axels, May Be 1 Is Bent.
      also, a failing inboard cv joint can cause that at different vehicle speeds.
      are you sure it is rpm related and not vehicle speed related? Does the engine do it when it is in neutral and you rev the engine to those "trigger' rpms?
        torque converter
          Mine shakes while stop at red lights; I replaced the front engine mount with a $20 cheap one from ebay and didn't fix it, I think was too soft.
          The one from the dealer is $100
            it doesn't vibrate at all in nuetral and when i rev it doesn't do it either it seems like it does it the most between 15-35 mph in 1st and 2nd
              vibration
              i can fix it easy ....
              Big 'C' Macin
                are you going to give advice or just state your amazing abilities? PEACE
                MY MEMBERS RIDE THREAD
                  Im not sure, but maybe your tries are imbalanced, or they have bad wear spots. Maybe alignment.
                    how old are your axles? Over time the CV joint go bad and they'll tend to get some "play" in them. Do this: jack up your car and tug on your axles, if they have any amount of play, then its definitely your CV joints causing it.
                    Mine was so bad at one point that when I accelerated on the freeway, my doorpanels would shake.
                      He's got some MAD mind powers!!! He turned me into a newt.....
                      I got better.
                      Been a long time. Still alive...
