HOW TO adjust rear camber with <=1" drop
    see the two bolts holding in the upper arm next to the spring? take on 2/3 out and one all the way out.
    using longer bolts, insert washers between the unibody and suspension
    and i used a magnet to hold em in place while i lined up the bolt
    torque to 38 Ft/Lb per ingallseng.com
    didnt even have to use the buzz box, one thing i dont miss about working on jeeps
    that's cool...and creative. kinda like using shims to adjust camber on gm vehicles. i liked using the camber kit from ingalls tho. made it a lot easier to adjust for street driving and for track days.
    Originally posted by HardInThePaint
    Girls should most definitely rep the shocker. Embrace the shocker.
    Be one with the shocker.
    My ride: http://www.cb7tuner.com/vbb/showthread.php?t=187897
      can you take a picture of where they go.
      you got all these pictures but no picture of the washers installed..........
        they just go behind the two bolts in the first picture
          so does this work with the stock suspension too? or no? and afterwards u have to go get teh car re aligned? or can u drive it without doing that if u only drop like maybe an inch or 2?
              forgot to ask as well does anyone have pictures of this when it is finished?? cuz i want to know how my car should look when finished...haha thank you
                no one has a pic of their car when they finished doing this dyi?
                  Originally posted by yeamans17 View Post
                  So far you've asked if you can do this with a stock suspension, the answer is yes, but why? This is to adjust the camber after you lower a car, on a stock suspension set up you would be better off getting an alignment. The way this should look after you've finished is like a car with closer to 0 degress of camber. I'm not sure what you don't understand about what he posted, he took some washers and put them between the upper control arm mount and the body. If you don't understand that please put down the tools...
                  I second that motion. save yourself and your car por favor.
                  Patiently Waiting.
                  MRT
                    you should get your car aligned anytime you do something to your suspension. hell, you should get the alignment checked about every 6 months as preventative maintenance.
                    but ummmm, yeah. i kinda agree with the other guys. it may come off as rude, but they're right. an inexperienced mechanic more often does more harm than good. the best idea is to get a friend that can bend wrenches and work on the ride together and have him teach you. everyone's gotta start somewhere. hell, the first oil change i did i forgot to put the oil cap back on and when i shut the hood, the cap went through the hood. first day of a new job too. talk about embarassing.
                      haha okay...well i can do this however i was just wondering things before i start doing things to my car...i just like to know things before hand how it should turn out...cuz i thought this would lower my back because i dont like how it seems like its floating higher than the fron thats all.
                        nah, it won't lower the back. when you lower your car via various suspension changes, the tires lean in. that lean is your camber angle. leaning in is negative camber and leaning out is positive camber. those washers would be a way to correct that negative camber. or aftermarket camber kits are available that have adjustable camber so you can get it dialed in just right. i ran ingalls adjustable upper control arms on the rear and adjustable balljoints on the front. got a good aligner to align it (me lol) and had that sucker dialed in tight.
