cb7 pully on cd5 belt
    situation:
    - running cb7 alternator on cd5 engine
    - using cb7 pully (5 grooves), cd5 have 6 grooves
    - using cd5 belt (6 grooves)
    - crank pully cd5 (6 grooves)
    - end result, cd5 belt is a little wider on cb7 pulley
    bad idea???? only temporary til i swap the correct pulleys to cd5
    I'd say you're safe. Worst case scenario is the belt breaks and you lose electrical power, but I don't see why it would. Plus you're not planning on running it forever.
    If I were you though, I'd even consider just leaving it on and keeping an eye on the belt. Wait for your next belt change to swap the alternator pulley. Or maybe that's too Frankenstein-y.
      I'd say go to Autozone and buy the 5 groove belt. 6 groove belt on a 5 groove pully = slippage. If that belt rolls over the alternator pully chances are you're going to have some problems.
        I'd say you're safe. Worst case scenario that I see is that the belt breaks and you lose electrical power, but I don't see why it would. Plus you're not planning on running it forever.
        You could probably just leave it on and keep an eye on the belt. Why bother pulling the belt off to change the pulley on the alternator until you really have to?
        Of course, if it were me I guess I'd switch the pulleys soon, just for the sake of form.
