okay so 3 days ago i got my coupe running again after swapping in what was suppose to be 30,000 under h22a. everything is fun and running good, last night i go to start the car and a noise is coming from the top of the motor and not a bad rod or valve. doesnt sound like a lifter stuck open. it sounds like something is loose under the valve cover. does anyone have any ideas on what it could possible be? i taking a closer look tomorrow at it. any ideas would be helpful.
weird noise from motor
Red Wagon DD - 1993 EX
http://www.cb7tuner.com/vbb/showthread.php?t=172734
Gray Wagon Project - 1992 LX
http://www.cb7tuner.com/vbb/showthread.php?t=166337Tags: None
you might also wanna make sure you valve cover gasket is all the way in where its supposed to be. I made the stupid mistake of getting it caught up on the timing cover and half of it was inside, hangin' w/ the valvetrain lol. Luckily I caught it right away after test driving it and checking my work.
But also be sure that you don't have one of your valve nuts loose in there, that could also be another possibility if you did a valve adjustment or replaced those tube seals...idk.
