it could be the rubber lines or it could be a dirty motor
slow window
Check this link out. Mine are real bad, pushes the window out about 1/2" if I dont hold it in while going up. I still need to replace mine after I finish my suspension overhaul. Another person on this site gave me this link when I asked about it. Cheapest ive seen so far.
http://tasauto.com/Product/Browse.as...z=10&h=175&p=1"Brought to you by Carls Jr."
If there using white grease at a honda dealer then their looking for problems, that white grease gunks up after a while and slows the window, and will eventually damage the window run channel, I worked at a honda dealer, we used the regular lube. white grease is good for hinges and things to that nature, not good for lubing window run channels
Hey just wanted to know what this part was called also...because i have the same problem in both my front windows and it's the rubber part on the inside of the door at the bottom..what would be the best solution to do to get them running like new? Does honda still carry this part? Can i just walk in and ask if they have it? Any help would be appreciated..Thanks
Lou's Build Thread!
http://www.cb7tuner.com/vbb/showthread.php?t=181377
"G-Squares Are For Assholes"~PR_CB7
Go on www.hondaautomotiveparts.com and look around. You should be able to find the part in the diagrams... and also the name, price, and availability of it.
5th gen owner here looking to improve my front windows while I have the door panels off doing a speaker install.
I have the issue where my drivers side window just pops out of the track a bit right when it reaches the fully closed position. Going down it stays in place, and going up it usually stays in place until it reaches the top.
I will try the silicone spray in the rubber tracks, but if that doesnt fix the alignment issue any suggestions?
