Check Engine light and everything else
    my sports light blinks, my overdrive kicks off, speedometer doesnt work, odometer doesnt work, check engine light is on. anyone know WHAT THE FUCK it is and where it is and what i have to do to fix it. Thanks
    what the fuck is what?
    you need to tell us what codes you are throwing and how all this came to be.
    we are good but we still need background info
      Sounds like VSS.
      wat?
        Originally posted by C91BLX7 View Post
        Sounds like VSS.
        VSS is likely for the majority of your problems, but it would still be helpfule to understand what led up to these problems and what codes you have set.
          Sounds like VSS.
          My VSS was bad but the sports light didn't blink and the overdrive didn't kick off. you just don't know
            sounds like you just dont know.
            if your vss was bad to begin with then i would start by replacing it.
            it could have gotten so bad that it started screwing other shit up.
              First and foremost what code is it throwing from the CEL?
              Most likely its going to be the VSS but its good to check anyways.
              As for the overdrive blinking,hopefully is not your tranny takin a s***.
              www.PreludePower.com
              BB SQUAD MEMBER #28 V.2
