from what i was reading you also need to consider squeezing some of the shocks, springs and brakes in your budget now i basically am at the end of my budget and i need to know if any one can recommend what to buy pls
shocks and brakes
Brakes are more important than your shocks.
head over to http://www.tasauto.com and look up the brake packages.
If you dont want to change them yourself I think monro muffler and brake has a deal for $99 per axle set, which includes rotors and pads. I think labor too...
Also on a budget go for stock shocks and springs...
Don't buy ebay springs.
For brakes, Brembo blanks are good, and there are plenty of decent pads to choose from (Brembo also makes fantastic pads). The ROH conversion from TASauto will make things easy, but it's an investment.
Suspension, if you want to go on a budget... KYB GR2s are a good choice for struts. Springs, you'll have to shop around for what you want... H&R, Neuspeed, Tein, Progress, Eibach... Get a good name brand. Cheap no-name crap is garbage.
If you can't afford at least the things mentioned above, don't waste your money. Save a little longer.
Springs and shocks are absolute cake. I can do a CB7 suspension myself in about 2 hours. The spring compressor can be borrowed for free from Autoz0one.
Pads are cake. I did mine in 15 minutes while on the phone.
Rotors... not so easy on our cars, unless you do the ROH conversion that I mentioned previously. You CAN do them yourself, but that's a case where it might just be less frustration to have it done professionally.
BLUBB2, you obviously have no experience doing ANY of this, so why are you giving advice on it?
i did my front rotors last year and got it done easily by getting an extra pair of knuckles and changing the rotors/bearings/lower ball joints in those knuckles then just swap over the knuckles 1-2-3. but i have been doing auto mechanical work since i was 8. not exclusively on hondas but all types of cars
