I'm begining to think I bought a lemon...
I change the sparks from OEMs to NGK G-powers. Thing is when I removed the sparks hoards and hoards of oil saturated the plugs and it poured out of the socket wrench when i pulled it out of the tubes where they go...
I fire up the car with the new sparks, fails the first time, second time it goes fine, third time etc fine. I drive it around the block a little, rev the engine upto 3,000 rpm, all sounds ok except when its idling.. it sounds so weak and the steering wheel wobbles pretty hard.
Another note when I fired it up for the first time after spark changes white smoke billowed out the tail pipe, haha... but that only lasted for 3 seconds now it just has this extremely faint 'pops' of white smoke thats only visible if you look directly at the exhaust end. I'm figuring oil got into the compression chambers.. ehhh... I didnt tighten the spark plugs more than just 'snug' which i assume is the correct way. Blah... I already have a new alternator waiting to be installed to solve the eletrical problem.. but first things first...is my engine ok, is there anything i need to do, change or inspect?
are my fans fucked and i needae replace em or do they not fire up on idle or what.... blah i know how a pellican feels when its saturated in oil, i swear the oem nut and oil filter are a bitch to remove when theyre sealed hard.
