hydrogen? is anyone using it in the CB's?
    so has anyone hooked up any hydrogen or plan on putting hydrogen into the engine? i'm i'm planning on doing it, see if i get more power n at the same time increase my 22mpg to around 40-48mpg (hopefully)
    I was planning on doing it but ran out of funds. To make it work right you must a have a hydrogen fuel cell that creates tons of hydrogen.
    -1991 Honda Accord LX H22a-
      WTF!!! u dont need that fuel cell!!!! all u need is a jar of water, fill it up, n put an electric current onto the water n have a hose from the top of the lip into the intake manifold. u just have to make something so the water wont hyrdo lock. u just have to change out the water
        you don't know damn thing about Hydrogen. I suggest you learn more about it and dont blow your self. you know its vere explosive. It's all about how good of cell you have that can produce reasonable amount of brow gas to compensate for gas.
        I had in my cb for some time and not really worth unless you got big cell, like Joe cell or similar.
          gasoline is very explosive too. i've done research n i helped install one into afew trucks with relays n switchs. so when its off it doesnt go everywhere when the cars not on. fuel cells r over rated. just need to figure out how much volume of water n the amperage going into the water n how fast the hydrogen is . its safe as long as u know what ur doing
            Shit if you are in Indianapolis, come down to Bloomington and help me install one. I've seen videos of people using them on CB7s, don't know if they really work though...
            90 accord EX automatic F22A4 232,500
            DIY ram intake
            0gauge/4gauge BIG 3
            stock alt rewound to 120amps
            optima orange top 830cca 1030ca
            fully synthetic valvoline "Max Life" 5w30
            Other rides:
            2004 Jeep Liberty v6
            2001 Honda civic ex coupe 1.7 vtec
              read your sig line.....what brake indicator fix?
              Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
              ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
              ...this thread has been graced by the new CB7 King
                Do you know anything about KOH=POTASSIUM HYDROXIDE. get joe cell like this one http://cgi.ebay.com/JOE-CELL-HYDROGE...QQcmdZViewItem
                or make one your self that would start of 1/2in tude and finish 4in increasing by 0.5 inch, so 0.5, 1, 1.5, 2, 2.5, 3, 3.5, 4
                some one had made that one and it was producing 3.2lpm with 30 amp.
                mine was only making 0.9lpm but it was ss plates design.
                  i'll help u but i have to find the sweet spot so i can place the water n figure out where to put the switchs. plus i'm moving from indianapolis nov 14 or 21 this year lol. sorry i love my cb7 i dont use ebay stuff on my beloved
                    I just wrote it up at http://www.cb7tuner.com/vbb/showthread.php?t=112919
                    but here is what I wrote:
                    If you are that annoyed by that....DISABLE IT.
                    There is a brown box on the driver's side tail light, there is a wiring harness coming OUT of it. Find the WHITE wire with a GREEN stripe on it. Now becareful not to get a green wire with the white strip on it, b/c those are not the correct wires.
                    Anyway, solid WHITE WIRE with GREEN STRIPE, cut it, and extend it(aka use a butt "connector" to add more wire, I used 14gauge so it is longer), and GROUND IT. I just grounded it to one of the 4 bolts that hold in the taillights.
                    IT WILL BY-PASS THE "BRAKE LAMP" INDICATOR check so it never comes on again.
                    CREDIT FOR THIS FIX goes to : cp[mike] as he mentioned it in another thread and it works perfectly.
                    DIY ram intake
                    0gauge/4gauge BIG 3
                    Other rides:
                      where are you moving to? I'm interested in this hydrogen stuff
                      DIY ram intake
                      0gauge/4gauge BIG 3
                      Other rides:
                        im also interested in a hydrogen "cell". that joe cell looks great for surface area. anyone ever try switching the parrelity rapidly?
                          when i make mine i'll post it but i want my water to b by the engine lol. i'm going back home to atlanta, georgia, but i love it up here well mostly ohio lol
                            it isn't worth it, it takes more energy input to create the splitting of oxygen and hydrogen than the hydrogen can output.
                            A car battery doesnt create enough hydrogen constantly to keep a car running, at least to my knowledge, if someone pulled it off kudos to them. I've heard of people using wire mesh stacked layer upon layer to create more surface for splitting h2o into o2 and hydro but eh....
                              http://www.cb7tuner.com/vbb/showthre...45#post1627145
                              Don't be scammed!
                              AD5OS
                              FOLDING@home
