tranny issues
    tranny issues
    okay so heres the problem when driving my car the tranny usually shifts at around 2000 or 2500 rpm under normal driving but recently it wont shift to third untill i push the rpms to around 3000 or above there is no s light blinking no cel tranny fluid is at the correct level tcu has been replaced about a year ago but this is intermittent and doesnt present itself on a daily basis. does anyone have any idea what could be causing this maybe a bad tranny? i hope not but i do have another f22 tranny.any ideas will be taken into consideration
    h23a3 lxinks
    It could be the fluid, it could be failing shift solenoids, it could be the TCU, or it could be the internals of the tranny itself.
    I'd change the fluid with some authentic Honda ATF and see if that works. Then look at the shift solenoids.
      i just replaced the motor so the tranny fluid was changed as well at that time. i dint have this issue before changing the motor humm but i didnt use honda atf fluid so are our cras real picky when it comes to which type of fluid we use in the tranny?
      h23a3 lxinks
