Hi all,
I'm trying to change my timing belts and seals. The procedure became necessary because I had a big oil leak after the engine overheated (radiator and thermostat have since been changed).
I got to the point there I should remove the access bolt to the rear balance shaft maintenance hole, but this bolt seems stuck. I soak it with WD40 and tried with a 1/2 inch torque wrench but it looks I'm just destroying the bolt.
Could I do the procedure without locking the rear balance shaft (by relying on the marks on the wheel only)?
What is the best tool to loosen the timing belt tensioner adjusting nut? My problem is there not enough clearance to get either my 1/2 inch or my 3/8 inch socket wrenches on the nut. Or can you lower the engine so much the you could use an extension through the wheel well area?
Thanks for your help, I'm really stuck right now.
