vigor sway bar q's
    vigor sway bar q's
    ok, so i got a vigor sway bar from the junk yard with all of the mounts and went to go put it on the other day...
    it's the same shape, and definitely larger in diamater than the accord bar, but it's not exactly a "bolt in". The vigor mounts are longer on the mount side than the accord ones, and there isn't enough meat in them to re-drill holes in them, and the accord brackets won't fit over the larger bushings for the vigor bar, and the accord bushings don't fit over the larger vigor bar either, so I'm stuck... what has everyone done to the brackets to make this fit??
    what you have to do is use the accord brackets, but just bore out the bushing 2 mm to 16mm from 14mm. I did that and it worked perfectly for me. I just used a dremel to remove the rubber material.
