wit r main reasonsz for car losing oil?
Oil
Dat be da Lang Machine GUn THeM. Nat da Gun dat Sound LiKe PopCorN. Me gOtz Da LoNg MacCHiN3 Gun ThEm.Originally posted by jcoleman_11 View PostPRAA PRAA, classic
EDIT** I will stop doing this lol, last time I did this my posts got deleted.
To the OP please make the effort to type better so we can understand you and be able to provide you with better responses.Last edited by PUMASTi; 10-13-2008, 07:49 PM.
the oil is either leaking onto the ground or it is getting into the combustion chambers at a higher rate than usual and burning.
how much oil are you losing, and how fast do you lose it?
to check for leaks, put some clean cardboard under the engine when you park it overnight, then look at it in the morning.
for oil burning in the engine, small amounts of oil will mix in with the exhaust and look whitish, larger amounts would appear to create a darker, more blue-ish exhaust.
Translation:Originally posted by DrSzSoLDIeR View Postwit r main reasonsz for car losing oil?
Hello friends of www.cb7tuner.com,
What are the main reasons for a car to loose oil?
Thanks,
DrSzSoLDIeR
Originally posted by C91BLX7 View Postit dun b old yah feel me iz liek teh ol menz wit der diapersOriginally posted by DrSzSoLDIeR View Postaight good lookszOriginally posted by frootloops View Post
Am I really that out of touch that I can't read or understand the f**king question!?Originally posted by jcoleman_11 View Posti tihnk if you replace the i in wit with an a, then add an a and e to the beginning and end of the r. then we all know he loves his Zs so just ignore that letter, and finally add an a before car.
that should help you understand!Originally posted by tonymontana1204 View PostYo da CarZ Wez Got be LeeKing N shitzs N sumtimz be BurN&n ALl Da Oil. PRRA PRRAAAOriginally posted by jcoleman_11 View PostPRAA PRAA, classicOriginally posted by DrSzSoLDIeR View Postwit r main reasonsz for car losing oil?
type in english and not the way you speak so you dont get answers like these above. you wont get anywhere or any help if you decide to type that way. somje mods might even delete your thread.
type correctly or dont post. period.
Originally posted by batever View Postthe oil is either leaking onto the ground or it is getting into the combustion chambers at a higher rate than usual and burning.
for oil burning in the engine, small amounts of oil will mix in with the exhaust and look whitish, larger amounts would appear to create a darker, more blue-ish exhaust.thank you, you two, for taking the mature route and trying to comprehend his question and answering it.Originally posted by EJX_Michael View PostTranslation:
Thanks,
DrSzSoLDIeR
