Electrical load detector where is that located
its integrated with the under-hood fuse box. just to the right of the Hazard circuit. I think it has 3 wires and a skinny white connector.Originally posted by hondaguy305 View PostElectrical load detector where is that located
the whole box should be replaced for a repair.
check your grounds.
that was the problem for me when my CEL came back as the ELD.
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
yep.Originally posted by hondaguy305 View Postu mean change the whole fuse box
i have yet to find a different solution.
fuse boxes are easy to find, easy to remove and install, and are usually only about 20 bux at the junkyard.
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
good thing i have 2 accords....soon as i fix it i'm trading it for another cb7 H22 Vtec automatic wish me luckLast edited by hondaguy305; 10-14-2008, 02:28 AM.
You Can Catch me Ridin In My CB Eyes On The Rearview Lookin For The Police
never heard of the ELD going bad??Originally posted by Maple50175 View PostNever heard of this problem before.
it seems to happen more often than people think. although i figure that the ELD is not always the culprit.
as in my case of a bad ground.
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
why does it only flash the code once??Originally posted by hondaguy305 View Postwell im not good at reading codes...it only flashes once...but before i left the ground loose by the thrmostat housing....so i guess that messed it up..now the fuel is not pumping fuel hard enough
this is not normal. it should do it over and over.
did you tighten that ground?
after that you should reset your computer to make sure the code is gone.
if the code is still present it can affect the rest of the system.
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
oh.Originally posted by hondaguy305 View Postnaw im sayin that it blinks once then do a 3 second pause over and over
in that case it sounds like you either have a 1 or a 10 code on your computer.
neither of these have anything to do with your ELD.
is the flash fast or does it stay on for about a half-second?
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
