Replaced the header and downpipe... and when accelerating at a moderate/fast pace, I hear this rapid "ps ps ps ps" sound. My friend said it sounded like a gasket might be flapping... and what he smelled had an odor of that as well (I thought it smelled like clutch, but he hadn't slipped the clutch at all, so doubt it was that). Anyway, if anyone has any ideas, let me know... otherwise I'll just let the shop take a look at it. Thanks!
Final exhaust question
lol i didn't use a torque wrench on a damn one of my exhaust bolts..and mine are perfectly fineOriginally posted by Medikerik View PostIf you're referring to what I think you are, they were tightened down to spec... if not, I'll go poke around. The headers were torqued to 23 ft/lb like they were supposed to. Or am I mis-understanding the part you're referring to?
just tighten till your arms give out
http://www.tasauto.com/Product/Brows...z=10&h=175&p=1
I got it off ebay, and it was the one for a 93, but same thing. Same picture, anyway.
If you tightened to spec but the threads were dirty or rusty, you won't get the same clamping force as if for new bolts/nuts so you will have to apply more turning force to get the same bolt stretch. You probably don't want to take it apart and reassemble bcs then you might need to replace the gaskets. But try some WD40 or pb blast on the threads to help you to turn the nuts easier, then tighten them a little more. If you still are getting the leak, tighten a little more when the assembly is hot.
You say you got it off ebay. Was it a really cheap header from ebay? If so, those gaskets suck. There is a chance that the gasket connecting the downpipe to the header was not centered properly and you might have burnt part of it out if the gasket was hanging over the flange on the inside of the pipe. You should have thrown those gaskets that the header came with right in the garbage and used fel-pro gaskets instead. You could try disconnecting the header from downpipe and using Permatex copper sealant. Another thing it could be is the downpipe and header flanges are not sitting flush with each other. Trust me, I had this problem with a cheap ebay header before.Originally posted by Medikerik View Posthttp://www.tasauto.com/Product/Brows...z=10&h=175&p=1
Edit: Is this like the header you bought?
http://cgi.ebay.com/ebaymotors/90-93...=p4506.c0.m245
If so, I am about 95% sure that your problem is where the header meets the downpipeLast edited by AbsurdNY; 10-15-2008, 08:39 PM.
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
No thud. Just a very rapid sound, more like air escaping than a thud.
